Bad Supercharger?
Received 2,193 Likes
tisk tisk, 2 pages of posts and only 1 partially touched on first thing to diag. fuel pressure. this symptom is a common thing when fuel pump 2 goes bad in any sc jag. its comes on for boost/rpm above 3k. recieves a signal from the ecu to the rear electronic control module to relay 15 out to both fuses f-47, and f-49 both 15amps to the fuel pump 2 control module in the trunk then to the pump through pins 7, and 8 on the fuel tank cap under the passenger side rear seat. check the fuses and if bad replace both pumps. they go bad from too many amps when going bad(ie you can replace the fuse only to have it happen again). replace both cause youre going in there and theyre the same age. when the primary goes out youll be on the side of the road. if both fuses are good swap relays around to ck for bad relay. after those quicky checks run a fuel pressure test while driving. yes youll need a fuel pressure gauge and long line taped to the windshield or you can monitor through the message display in engineering mode. the reason it varies on falling on its face is because the primary pump can cover the added needs up to a point. the random misfires are from the engine leaning out so you get restricted performance and ck engine light cause it can cause engine damage if you continue. they go away with the problem but can probobly be seen depending on "trips to trigger". They can be found with a good scanner or jag ids or sdd under pending codes. forget the air box code not realtive to anything for this issue. Ive seen people block it open and take out without issue. to properly diag a car you cannot get bogged down with the chaff, you need to only look at the wheat and this is why I laugh when customers say"the car gives you codes and tells you whats wrong with it!" uhhhh yeah right, it gives you "clues" and you have to be the detective and know what clues are important and which ones up front are not important and ellimanate suspects, just like a cop
The following 2 users liked this post by Brutal:
styper526 (02-03-2011),
XJR_hunter (03-24-2022)
tisk tisk, 2 pages of posts and only 1 partially touched on first thing to diag. fuel pressure. this symptom is a common thing when fuel pump 2 goes bad in any sc jag. its comes on for boost/rpm above 3k. recieves a signal from the ecu to the rear electronic control module to relay 15 out to both fuses f-47, and f-49 both 15amps to the fuel pump 2 control module in the trunk then to the pump through pins 7, and 8 on the fuel tank cap under the passenger side rear seat. check the fuses and if bad replace both pumps. they go bad from too many amps when going bad(ie you can replace the fuse only to have it happen again). replace both cause youre going in there and theyre the same age. when the primary goes out youll be on the side of the road. if both fuses are good swap relays around to ck for bad relay. after those quicky checks run a fuel pressure test while driving. yes youll need a fuel pressure gauge and long line taped to the windshield or you can monitor through the message display in engineering mode. the reason it varies on falling on its face is because the primary pump can cover the added needs up to a point. the random misfires are from the engine leaning out so you get restricted performance and ck engine light cause it can cause engine damage if you continue. they go away with the problem but can probobly be seen depending on "trips to trigger". They can be found with a good scanner or jag ids or sdd under pending codes. forget the air box code not realtive to anything for this issue. Ive seen people block it open and take out without issue. to properly diag a car you cannot get bogged down with the chaff, you need to only look at the wheat and this is why I laugh when customers say"the car gives you codes and tells you whats wrong with it!" uhhhh yeah right, it gives you "clues" and you have to be the detective and know what clues are important and which ones up front are important and ellimanate suspects, just like a cop![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Take care,
George
Superchargers do fail! The one on my car was replaced prior to me buying it. And the prior owner WAS a member here. I sent him a message but was ignored. Here's his thread.
https://www.jaguarforums.com/forum/s...ad.php?t=20806
sc's rarely fail, what you experiance is they "KNOCK" at idle. and Im not talking about a little, all knock alittle, its just the clearance noise of the rotors against each other at idle under no load. Just like a driveshaft and diff when you rotate the driveskaft back and forth by hand. You feel and hear the clearnace taken up between the drive and coast side of gears, axles etc.....
Its when the knocking becomes very loud at idle. The from drive coupling inside wears on contributes to most of the change. All SC knock some, you really need to know whats normal and whats not. for instance, Ive replace 1 sc for noise in 14 years, and seen only a few replaced in the shop otherwise.
#28
I'm sure he would have gotten to the fuel pump eventually but I wonder if he would have tried to pass the buck on the S/C.
Oh and jagv8 - you need to get a copy of scanmaster-elm if you have an ELM 327. I can provide you with a copy off forum if needed. It does real time 02 monitoring with calculated mixture
Take care,
George
#30
#31
#32
well guys, Unfortunately after pressuring this local shop to hunt around and try some other diagnostics, I am also convinced its the S/C. There is way too much noise comming out of that thing to be normal. they have found me a used one with 38K miles off a totaled STR. I also confirmed with the shop owner that if my car runs the same after they install a new S/C its not coming back on me. Im poking around town in a rental nissan versa and cannot find anything positive about driving this crap trap. Hoopefully i will be back up and running on im my STR tuesday. I will let you all know!
#33
well guys, Unfortunately after pressuring this local shop to hunt around and try some other diagnostics, I am also convinced its the S/C. There is way too much noise comming out of that thing to be normal. they have found me a used one with 38K miles off a totaled STR. I also confirmed with the shop owner that if my car runs the same after they install a new S/C its not coming back on me. Im poking around town in a rental nissan versa and cannot find anything positive about driving this crap trap. Hoopefully i will be back up and running on im my STR tuesday. I will let you all know!!
#34
styper526 (02-10-2011)
#35
#36
The following 2 users liked this post by JagV8:
styper526 (02-10-2011),
#37
FS[Central US]: 2010 Jaguar XFR
Rakka
11-02-2015 09:06 PM
Col. Sandurz
09-28-2015 12:49 PM
