ball joint nut coming loose
i have a 2002 s type 4 lt. v8. I replaced the lower ball joint assy. and the nut keep coming loose , i tried double nuts , loctite , drilling through the nut and stud and installed a pin and have the same problem .any idea as to why this is happening? Couple of days ago the stud snapped and the wheel was turned almost 90 degrees outward and caused damages to to the fender . Luckily nobody got hurt .
Jaguar has had problems with the X200 front lower ball joints since the beginning.
R136 (S204-R136) was issued to address loose bolts.
You might have a faulty replaced joint or it was damaged during install.
The design was changed with the X202.
The hole in the lower control arm might be damaged so inspect that also.
bob gauff
bob gauff
Received 2,190 Likes
al_roethlisberger
09-11-2015 10:04 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
