Barcelona on 2003 str
HI EVERYONE
AM planning to buy set of barcelona wheels for my 2003 str
the are 19 x 8" front 60 offset
19X 9.5 rear 60 offset
just wondering they work right out of box or some modification required?
and what tire size and pressure is recommended ?
can i get wider or higher profile
i curbed my zeus and hit a pothole and had to pay 800$ for repair on all 4 wheels , now running totally vibration free but i was gone on barcelona's the moment i saw them ?
cheers
cheers
Last edited by godfatty420; 10-24-2011 at 01:31 PM. Reason: changing notification from daily to instant and spell mistake
godfatty420 (10-25-2011)
I think it'll only through a code if Left and Right are different. I've had some VERY different sizes on other vehicals with Stability controls, and ABS. But the Jag is different and VERY much electrical, so who knows.
But yes your speedo will be off for sure. Larger tire = speedo slow. If it shows 70 for example, you could be doing 78mph GPS. Smaller tire = speedo fast. It'll show a higher MPH then actual speed.
godfatty420 (10-26-2011)
if stock str can take increase from 18" to 19" or even 20" , i dont think 5-10% increase in profile of tire will matter
thanks for warning me and making me do research on it
stock tire diameter (35% of 275 ) + 18" = 96.25MM + 457.2 mm = 553.45mm
circumference = 553.45 x 3.14 = 1737.8 MM
barcelona rear setup
diameter = (35% of 275) + 19" = 96.25 + 482.6 = 578.85 MM
difference = 25.4 = 4.5 %
since at stock it reads 96kmph on gps with needle at 100 , i think it will be perfect
its just a comparison on both setup my way , not implying this is the correct way
i hope my way of calculating all this was correct
You will also affect handling if you do as you propose.
agree
i am pretty laid back driver , never speed through corners , just occassional straight wot , just dont want to bend or break rims , and want to confirm fitment , no other concern
cheers
SoCalJagS
09-27-2015 09:20 AM
