Battery
Hi new to this site and need some advice
I have a 2005 s type 2.7 d it is throwing up loads of fault codes egr turbo drivers door module abs some are showing low voltage before I spend loads of money just want some advice as I have read a lot of posts on low battery I checked the battery after leaving the car all night and it's showing 12.2 volts with the boot light on yesterday it was showing 12.4 after running around most of the day just wondering if this voltage is to low shows 14,5 with engine running cheers
Nooooo.....the battery voltage is too low.
Jags are notoriously fickle on battery voltage. You should be reading 12.6v after standing overnight, anything lower stands the chance it'll throw a code or EML
Plus if you only use it for short journeys that'll not charge it enough to maintain the systems requirements.
You could try putting it on a battery tender overnight, clear the fault codes, check the voltage in the morning to make sure it is up around 12.6v, then have a run around for an hour or two. See if the fault codes re-appear. But I suspect not.
And as you say in your post, if you have run around most of the day and it is showing 12.4 volts, then I would supect that it has a dying cell in it anyway.
Another case of a bad battery causing undue mayhem for Karl
More than you ever wanted to know about batteries here:
https://www.jaguarforums.com/forum/s...attery-193787/
Please note a new battery is not a guaranteed fix, but if the condition is suspect, it's worth a gamble. Per the scorecard so far, the odds are about 50%. That may seem low, but is actually quite high for a single component causing otherwise unexplainable problems.
Also make sure to rule out other factors causing low pre-start voltage. It sounds like your alternator is charging okay, but you could still have a low usage driving pattern or battery drain that is complicating things. For troubleshooting, you can hook up a charger every night for a week so you'd know the battery is fully topped off at the start of each day. If the car now behaves itself, you'd know the issue were caused by low pre-start voltage.
180 pounds just for labor? Oy vey, that's spendy.
You'll need to do the throttle calibration:
https://www.jaguarforums.com/forum/s...ection-176446/
Also, if you have the factory radio, I think it will require a security code. Most markets don't require it, but I think the UK models do.
Hi yes very pricey bloody rip off over here it's booked in for next week at independent jag specialist £150 fitted and calibrated the radio is coded I have the codes so should be OK thanks for your time I have downloaded the info you sent me gives me something to read later on cheers Chris
Received 6,313 Likes
Thanks for the advice guys had the battery checked at local workshop they said battery running at 48% they can't change it need to take it to a jaguar garage I phoned them and they quoted me £165 for the battery and £180 to fit it bugger that local independent £150 all in cheers Chris
![Icon Eek](https://www.jaguarforums.com/forum/images/smilies/icon_eek.gif)
£150 still makes the eyes water.
Received 2,636 Likes
snkpkp
01-14-2021 09:52 AM
BigCat09
12-04-2019 03:06 PM
cat_as_trophy
01-26-2014 07:40 PM
Mark Scotton
24
01-23-2013 09:27 PM
Mccalist
12-14-2009 09:05 AM
