Battery dead manual locks cannot open
Hi I have a 2000 jaguar s type. i haven't used it for a month. The battery is dead and I cannot turn the key hole manually in the driver side and at the trunk. Its so hard to turn it might break the key. Is there any negative and positive terminal going to the battery that I can tap so that I can use my remote. I hope someone can help thanks
Welcome to the forum Krp,
I've moved your question from Jaguar Forums Advice / Feedback & Suggestion Center section to S-Type section. Members here with the same model will be able to advise on accessing terminals.
When you get a minute, please follow this link https://www.jaguarforums.com/forum/n...-intro-must-5/ to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
I already opened the car door. I took of the right front tire and connected the terminal from the starter motor to a battery and the car opened thru remote. The key that I'm using is the same key I use with the ignition and it came from the dealer maybe I need to put oil with the mechanisms anyway guys thanks for the tips
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
OkieTim
09-08-2015 04:48 PM
