Battery Overcharging
This recent thread may be of interest to you, with a battery killed by severe overcharging:
https://www.jaguarforums.com/forum/s...ut-out-228338/
The fix was a new battery and alternator.
Just curious, where are you taking the voltage reading? Directly on the battery posts? Meter test leads clipped to the battery terminal clamps, not the actual posts? Somewhere else, such as the alternator itself or the front power distribution box? I ask because if you have a marginal connection somewhere between the alternator and battery, the alternator output may "run away" to some extent.
When shopping for a new alternator, make sure the internal control board is an OEM unit. Most aftermarket alternators have a generic control board, and although it will adequately regulate the voltage, it doesn't communicate properly with the rest of the car. The result is the little red battery light on the dash will not work. The light is always illuminated or not at all, and so you won't have any warning of future charging problems.
The following 2 users liked this post by kr98664:
Catfan01 (02-03-2020),
S-Type Owner (02-04-2020)
Paulrwalkington
10-15-2017 12:57 AM
Compounder
01-13-2015 05:58 PM
