Battery Tender Routing
This thread may be of interest for an easier method to connect a battery tender:
https://www.jaguarforums.com/forum/s...ng-port-87362/
Rather than dealing with the leads in the trunk, you can connect via the front power distribution box under the hood. You can leave the hood open for ease in routing the wires. If you'd rather close the hood, you can prop it open a few inches with a block of wood or similar.
If you'd still prefer to connect directly at the battery, you can gently close the trunk lid on the wires. The seal will compress and not cause any damage.
Before putting the car away for the season, make sure the key works to manually unlock the trunk in case the battery tender fails and the battery goes flat. You can't believe how many tales of woe we've heard about a dead battery combined with a key that doesn't work.
Rober2
05-26-2022 11:42 AM
06-XJR
16
07-05-2016 11:13 AM
