battery warning light issue
Old 07-02-2017, 04:37 PM
JagV8's Avatar
Received 4,535 Likes on 3,944 Posts
What does it call it?
I don't actually see how it helps, since it's so trivial to read it with a meter as he has done...
(ETM will also show volts but again I can't see how it's any more use than the meter.)
Old 07-02-2017, 04:38 PM
frenchdave's Avatar
I have checked voltage of alternator with a multimeter at the battery
Monday I will test the alternator direct by using it to see if the values are the same.
Will let you know what I find
Old 07-02-2017, 06:04 PM
JagV8's Avatar
They should be slightly different due to the drop across the cables.
