Beeping noise after engine turn off
I stopped and filled up the half tank needed for full (premium 93) I made sure that the cap is fully closed, after leaving the station the car felt like something was pulling it to stop ( like a flat tire) I stopped looked around nothing seemed weird, turn it off and on again and off I went no problems, I got to work and after turning the car off , this rapid beep came on for about 12 seconds, no lights no warnings just the beep, I locked the car and when I unlocked it open the door and the 12 - 13 second beep came on again then only light that I could see on was the e-brake light for those 12 sec, and then the light and the beep stopped, the car starts and runs now ( fingers crossed).
Any ideas?
Any ideas?
Also, change the battery if it is as old as you say.. That would be insurance against anything crazy in the future...
now I have to search for re-calibrating the windows and sun roof.
Thanks a lot
Received 6,310 Likes
haha, right you are, I had it set up on automatic for the minute and half after locking the car the lights remained on for that period, now I have it just on automatic, and the new battery fixed the problem, then I had to re-calibrate the e brake and .. voila!!
Thanks a lot
Thanks a lot
The roof is fairly straightforward too, there is a link in the FAQ's.
Ok all I, Sorry ive not been around much, life has thrown me some curves, and i havent really been near a pc.
Im having something similar, and im trying to fix it without going to the shop. Ive been getting the System engine fault. If i start it a few times itll go away, sometimes it comes back. If I turn the car off sometimes I get a constant beep like the post says. Once I can get the car running for a bit it seems fine, but then i have the same problem the next day
The Car stays in the garage at night, and also I let it sit for the past week. So far, I have replaced the battery. I have reset the parking brake. I thought it was fine, but it acted up a day later. I dont know what else to do. I know theres something i hear with the TPS, but not sure what im all supposed to do. Any help or direction to start looking at is appreciated
Ps. I dont know if it could add to the problem, but about 3 years ago I had an auto start put on. not sure if system engine fault can have anything to do with it, but thought id mention it.. Thanks.
I would strongly recommend pulling the remote start and go about "fixing" any possible wiring issues caused by splicing in that devise. These cars run on a network and really don't like their electrical systems messed with. Heck, they get confused enough when there isn't any splices in the system......
Even when installing an aftermarket piece of audio equipment, you need to be VERY carefull where you pull power from. Changes in current flow tend to **** these cars off.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
