Belt squeal sound all the time (not just when cold)?
I've only owned the car for 2000 miles...At about 1000 mile mark I had the 3lb pulley installed and now soon after it started to squeal...Sounds like it's the belt but I can't confirm and thought it was only common for the belt to squeal when cold...Any ideas?
Belt size, baerring starting to fail, contamination, a few thoughts there... But like JagV8 said, if you pull the blower belt, you can better get an idea at least what belt, o rpully is causing it.
A bad pully makes a crunching racket, less likely to make the belt squeel, but a pully not allinged corectly can make the belt squeel, also check that the tensioner is GTG.
Thats why I suggested belt grip because using WD40 would I thought more than likely just hide the noise by lubricating so it slips quietly and not fix the problem?
Received 2,263 Likes
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
