Best AfterMarket Brakes For '03 S Type R???
Performance Slotted and Drilled Rotors
SCRAPER SLOTS:
Full Sweep Scraper Slots dissipate heat, increases bite and reduces the stopping distance. Our slots also help to de-glaze and even out brake pads while throwing dust and debris away from the wheels. It also sheds water under-wet driving conditions.
BALANCED & VENTED:
All Brake Performance Rotors are Machine Balanced, Vented for cooling (unless OEM rotors were solid from the factory), X-Ray Inspected and manufactured to meet QS and ISO quality system standards. Manufactured from Premium Quality Solid Casting, TUV approved steel.
RUST PREVENTION:
Our Performance Rotors have a corrosion protection finish that is electrostatically applied onto the rotors in chemical tanks (not sprayed on like inferior powder coating). Our premium quality Zinc Plating remains on all areas including inside slots and holes that do not come into contact with the brake pads. Available in Silver or Black.
http://brakeperformance.com/site/bra...php?&ad=direct
Pads
CERAMIC PADS:
• Longest Pad Life
• Lowest Brake Dust
• Extends Life Of Rotors
• For Everyday Driving
SEMI-METALLIC PADS:
• Ideal For Heavy Vehicles
• Highest Friction Level
• Performance In High Temp.
• Low Brake Dust
Here is a copy of the email from Andy at Brake Performance with a guote for four rotors and four ceramic pads for a package price of less than $800. No that is not a typo. His number is attached and he has a file on these parts.
Front Premium Slotted and Dimpled Brake Rotors............................$499.00 For Both Rotors including semi-metallic pads
Rear Premium Slotted and Dimpled Brake Rotors.............................$265.00 For Both Rotors including semi-metallic pads
Upgrade to Ceramic Brake Pads.............................................. ........$10.00 Per Set
Free Shipping-Free Zinc Coating In Black or Silver
To order call us toll free at 1-866-756-5536.
Thank You
Andy
Received 2,192 Likes
I just switched my wifes vdp from factory rotors and green stuff ebc to ebc dimpled and slotted with red stuff pads front and rear pads, and rotors shipped for $530. And love these, they brake way better and ive been a big factory believer even using "other" performance pads till i changed to ebc red
Thanks for the reply guys, it is appreciated...
Brutal, where did you order your set from??? That price included front and rear slotted and drilled rotors as well as ceramic pads??? That is a great price...
Interesting. Got a quote of 400 for front and rears for my standard S. They suggested I go with premium semi-metalic pads because of the lack of bite with ceramics. I was going to do drilled/slotted with ceramics until they said I may have an issue with bite. I sounds like they may be wrong. I deal with highway stop and go. Real crappy commute into Cleveland area. So, I need brakes that will grab and dissipate heat well. Man, I hate getting a pulse in my wheel.
http://www.buybrakes.com/
http://www.autoanything.com/brands/102A494.aspx
Ive ordered, from both and both have great prices
Looking into EBC, the largest rotor they offer is 12.6" Front (Product #GD1411) and 11.8" (Product #GD951) Rear...
The standard Brembos are 355mm Front and I believe 330mm Rear, does anyone know if these will work and work with the current Brembo calipers???
I looked at the EBC Brake manufacturer specifications, but the fitments stopped at the '03 4.2 Sport readings (nothing for Type R)...and I have heard of many people using these for the Type R setup...TIA...
![Cool](https://www.jaguarforums.com/forum/images/icons/icon6.gif)
Pick what works flawlessly and better than OEM. You won't miss the brake dust and the STR OEM brakes grabbing.
I think many folks have used EBC red ceramic pads and I believe the fitment for the brembo brakes are DP31462C for the front and DP31140C for the rear. I think I have a previous post that compares the rotor wear of the OEM (semi metallic) to the EBC reds. EBC does not make rotors for the brembo. Aside from the OEM, an earlier post is the first non-OEM vendor that sells aftermarket rotors. I think their std rotors are priced like the factory but they offer an upgrade path.
FYI, I just measured the lip on on surface of the rotor that doesn't wear and its about 2.5 mm think. With a 355mm rotor, the rotor radius would be 5 mm shorter so about 2.5 mm of the pad would be beyond the rotor. I believe the 355 mm rotors are for the later R's that don't have the brembo option. I know that on a few websites, the 355 mm rotor comes up as the correct fitment for the brembo cars.
You cannot compromise on the rotor size or the pads. I posted earlier on this thread where to get what ya need for chump change compared to OEM parts. I have installed their products on three vehicles I have owned and they are stellar. An STS, Land Rover and my STR.
Those were the answers I was looking for, looks like Brake Performance it is...
Looking at the calipers from the STR tonight (whilst thinking how fast I could bolt some parts on) I couldn't help but notice how similar the calipers are to a set of Porsche calipers I have on the shelf...I know the rotors are a bit thinner on the Jag than what the 911 takes, but can someone measure the thickness of a set of NEW STR pads for me?
It is entirely possible that a Porsche pad would fit. The brake pad retaining pins are identical. Not that Porsche pads are a bargain, but it does open up a bunch of additional manufacturers to shop from.
For a brand new Akebono pads for the front styper rotor, I get a friction material thickness of 0.382" and overall thickness with shim, backing plate, and rotor is 0.626". I think new rotors are 1.2" thick. Inside and outside pads are identical
Great if you can get the porsche pads to fit, even better if you can get the cheaper cross drilled porsche turbo rotors to work on the Jag!
