Best AfterMarket Brakes For '03 S Type R???
That'd be nice, but you would have to have custom hats made and do a two-piece rotor, if you can get the hats done for a reasonable cost, you would open a HUGE amount of aftermarket rotor possibilities.
A talented machine shop could make up the hats....but a to have a small amount made would likely be cost-prohibitive.
I've briefly looked into the two piece rotor options. From a cost perspective, its not bad and the break even point is two or three sets of rotors. The first disk + hat is more expensive then the stock rotors but the replacement disks are much less. If you replace the rotors three times or more, it actually gets cheaper. Assuming that the 1st OEM set lasted about 25k miles, you need to keep the car for about 75K miles or in my case, 12 years to realize a saving. Due to the long time, it may make sense to order the replacment disks at the same time which up front cost.
The main draw back is that the racing rotors are uncoated steel so the non-worn areas will have a light rust coating that some people may care about (not some much of an issue in So. Cal.). The other draw back is that you need to send them a sample rotor for them to make measurements (they haven't done a S-type R hat yet).
On the other hand, if there is enough interest here for a larger volume custom "group buy", the per set cost may be much more reasonable. I think the cost is mostly driven by the NRE cost in designing the hats. On a similar note, brakeperformance makes custom rotors to order and their price is similar to the OEM list but adds cross drilled or slotted features. It may be possible to work out a group buy with them if there is enough interest. I know I am up for a new set of rotors now.
stanjag
08-30-2015 10:35 AM
