Best alternative to buying new dealer STR exhaust manifold
Perhaps find a local shop that is competent to build you custom headers. I'm sure that the custom built headers will be cheaper that OEM manifold bought at a dealership, and will yiled higher performance than a manifold. The only draw back will be that if they use cheap or thin metal, you may get cracking. I would find a shop with a good reputation and express your concerns about cracking and ask about quality/thickness of metal and if they will gaurantee their headers.
I am thinking about getting custom headers built myself in the future.
Here is an online shop that will make custom headers if you cant find one in your area...
http://www.stainlessheaders.com/customheaders
Custom Headers Built To Your Specifications
I'm looking to save money and end up with a new exhaust manifold or header.
Guys the header thing has already been answered. There was a set floating around and they were finally installed on a Lincoln LS after going thru about 5 different people. They were about $1500.
The guy that installed them swore he would never do it again. A very tough job!
Do a forum search and you will find all the threads with pictures of the headers. They were very nicely made and it's a shame they did not sell.
This is who made them. They no longer list them because there was no demand. I am sure a call to the people below will flesh out the entire sad story.
Stainless Works Performance Headers & Exhausts
Recently replaced the passenger exhaust manifold with a used unit from Euro Chop Shop (California?) $140. Had it machined ($100). The heat shield is often destroyed during whilst the mechanic disassembles the old manifold, so if you need a very good condition passenger side heat shield ($25).
It is cast iron and the cat is not apart of it.
I can hear a small exhaust leak only under load so its not easy to find when your under the hood so I'm hoping to find out if there is a common side that tends to fail so I have a better idea where to look
rachelstr
09-03-2015 12:59 PM
