Bi-Xenon Headlights
Old 11-25-2013 | 06:31 AM
abulger's Avatar
Default Bi-Xenon Headlights
Hello! I have a 2003 Jaguar S-Type 3.0 L. I have 'repaired' my auto leveling headlights with the screw method I found on YouTube. However, my actual headlights are very dim. The dealer has stated that I must replace the entire unit, @ $900 each, in order to replace the headlights. Yes, I am a Girl who is just really learning how to maintain and fix her beloved car. Any advice? Thank you.
Old 11-25-2013 | 07:36 AM
JagV8's Avatar
If it's just the bulbs you can replace them without needing to buy the entire unit. I wouldn't let a dealer do it due to the cost.
edit: pah! "but" changed to "buy"
Old 11-25-2013 | 10:28 AM
Ingo's Avatar
If its been fixed with the screw method then there is no need to replace them entirely. Dont do it at the dealer, take it to a local mechanic and have him put brighter bulbs in for you. Should only take him 20 mins to do so. You can save some money buying the bulbs yourself at a local auto parts store.
Old 11-26-2013 | 12:33 AM
Tee-eye's Avatar
You have the xenon HID arc lamp headlights? You'll need the special capsule. It's not a regular headlight bulb. Search on the forum for the spec. I've never replaced one but reportedly it is not an easy job. I think you have to take the bumper cover off and take the headlights out. A body shop should be able to do that for less cost than a regular auto mechanic shop. The S-types do not have BI-xenon headlights, though. The low beam is xenon HID but it does not have the movable cut-off shroud and the high beam is the inner headlight which has a regular halogen filament bulb.
I don't think you'll need a brighter bulb. The HIDs are bright at stock/OEM level. What you probably need is headlight aim and maybe the outer headlight lenses to be polished and de-oxidized.
hoodun
11-20-2022 02:35 PM
kingdom worker
11-14-2020 03:47 PM
sdelliott58
09-28-2015 11:21 PM
Fletch44
09-28-2015 02:21 PM
kevinl
09-24-2015 08:25 PM
Quick Reply: Bi-Xenon Headlights
