Bizarre Headlight Pattern
Hi. I'm new to the forum. I just purchased a 2002 S type 3.0 and noticed the headlights (low beams) appeared to be aimed high. On trying to adjust, I found that the right headlight was projecting a very scattered and diffuse pattern. On further examination I noted that, on the right side, the reflector was separated from the front bezel (not the lens) by about 1/2 inch while the left (normal, I think) reflector was flush. While I was able to lower the beam with the adjustment screw the pattern remains very scattered. I didn't try fiddling with the bulb because I thought the entire assembly might be misaligned. The trouble is I don't see a way to move the reflector assembly forward (assuming it's the left headlamp which is "wrong" and the right is "right." Any ideas? Thanks in advance.
Received 2,190 Likes
