Blank Nav Screen help
Guest
Posts: n/a
I have a 2003 S-type The naviagation screen has gone blank and the buttons around screen do not work. LCD screen below units flashes S0 & S1 and C1. I took to the dealer and they say I need new navigation module in the trunk at a cost of $4,400 or Amp they don't know. I disconnected battery and checked fuses before taking to the dealer, with no luck. Has anyone else had this problem and what did they do? Also is there a way to bypass this unit so the air & heat works? Or is there a cheaper fix? Thank-you
I had the exact same thing happen to me. Were you playing around with the diagnostic screens by any chance? If so, you may have erased the the firmware for the NAV. When this happened to my car all they had to do was reinstall the firmware and reboot the system. It took about 30 minutes. The same message was flashing on my screen and I think the only thing working were the defrosters and all of the buttons were dead. Unfortunately the majority of Jaguar dealers will try to sell you a whole new NAV system because they need the business and the service writers get paid on commission, so a $4,400 repair is better for their pockets than the $120 they charged to fix mine. Eric
Guest
Posts: n/a
I was not playing with the set-up screen I am really not that advanced on knowing how to do those type of things. I was told by the dealer ( when I took it in yesterday) that my system my only need software updates. They said they tried that and it didn't work. Then they said my system may have come unplugged, they checked that was plugged in. Then they said it may be amp or Nav system they don't know. Is the firmware different then software updates?
Well if it just happened out of the blue, then your problem may be more serious than mine. If it does turn out that you need a new one, I would check ebay.
http://cgi.ebay.com/ebaymotors/2003-...item2ea573a372
They usually have a bunch. I only found a couple today, but if you can wait you can probably find a deal on a replacement. Eric
I started the Jag to go to work today, and, the NAV screen was blank. None of the buttons around it did anything. I backed her out of the garage, and, restarted the car. This time the Screen came up normally, and, its worked OK all day. Hope this was a one-time gremlin.
Regards:
Oldengineer
Regards:
Oldengineer
Regards:
Oldengineer
Regards:
Oldengineer
Its good to know that I'm not alone. I had the screen come up blank about once every few months since day one. Dealer has looked into it 7 or 8 times can can't find a issue (even after bring it in to them locked up). They have updated the software, tore out the unit to check for bad ground connections, called the factory, etc. Seems to always work if you stop the engine and restart. Anyone else with this problem?
All British cars are notorious for electrical quirks.. Austin Healey's, Jaguar's, and MG's. The Brits build beautiful cars, but for some reason it always seems like they have a room full of drunks engineering the electrical. Haha who knows, to me it just gives the car some character and it's one of those things you likely never figure out.
I was playing around with the NAV system after work yesterday, and, it's still not working correctly. I have a couple of questions about it.
1. Will it hurt anything if I disconnect the battery for a few minutes, and, see if that fixes it??
2. My car is a Jag CPO vehicle - will the extended warranty cover the NAV system if it requires a trip to the dealer to fix it. I'm currently at 53K miles.
The problem with the NAV - it won't let me enter a new address - it simply lists the saved ones, and, wants to direct me to one of those. I told it to go home, and, it wasn't giving me any voice directions as well.
Appreciate any help you can give me.
Regards:
Oldengineer
Regards:
Oldengineer
About a year ago on my STR, I started it and the navi was "black screened" then I restarted the car later and it worked fine. Just a few days ago the navi did not come up and is a black screen with the same codes as the original poster. I disconnected the battery and have been driving it for the last few days and it is still down (black screen, no controls work, etc...) I'm hoping it is not something major!
Chaps,
My 2004 XJ8 does this very occasionally. Although mildly annoying I can live with it. This is nothing compared to the constant problems I had with my previous car - a Mercedes E320. Now THAT is a car company with not just an Electrical engineering department, but also a Powertrain, Transmissions, Body and Chassis departments full of drunks. My E-Class just doesn't compare to the XJ. 3 years on and I still get a thrill driving it!
My 03 STR os currently at a Louisville ky. dealership for this issue. Same codes on the temp display and no buttons work. they are charging me $125.00/hour for Diag. and are on hour 3!!! Please Help! anyone have a short cut for them? any ideas to keep this from getting outragiously expensive? the tech there says he has never seen this before and was having trouble finding a soultion for those codes.....I wanted to ask him what traning he recived to work at the dealership.
$125/hr is not excessive.... but if they haven't seen it before (and they likely haven't) how long do YOU want them to go on? Be realistic, no training can cover every possible fault on a car like an STR. Not enough years before death.
Now, that doesn't mean another tech would take as long because let's face it some are better than others (same as in any job). Heck, another could take longer!
OK, I'm not helping - sorry - except to say maybe call a stop soonish, get details of what's been tried (make notes), then either try another shop or DIY, perhaps posting more info here. DIY might mean all manner of things, including swapping scarily expensive parts![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
If you're near any of the techs who post here.... seriously think about hiring one if you don't/can't DIY. If you can DIY, first get jtis (ebay) if you haven't already, then people here have had various parts out and so on, so may have ideas.
Best I can suggest, sorry.
Oh - I'd be checking battery, grounds and so on at some point. Basic stuff first unless there's a more obvious suspect.
Thanks for the reply. Im in a decent position considering the age of my STR I purchased an extended warranty through the dealership and the repair/replacement of the faulted part will be covered...however i am responsible for the diag. when i spoke with the service manager he just seemed baffled and told me the techs are too. Not a good sign....Im not down and out or anything, just slightly frustrated. I figured it would be a module swap and i would be out the door with just paying my $100.00 deductible. they pulled this on me with my last coil pack failure. I told them it was a coil pack and that i had the same problem 5K mi. ago. 2.7 hrs. of diag later they where removing the supercharger....Convinced the S/C pulley and intake i had installed were causing the problem they were discussing my full pay options. i fought tooth and nail. they finally looked further and discovered a bad coil pack...Im sure they do this for the $$. surely the techs are not that dumb, but i hold my reservations
