Blue tooth help needed
Under the center console. Remove cup holder. You will see a 20 torx screw under there. It just pulls up....2 piecces. Then inside arm rest box you will see another one rearward toward drivers side. Remove them. Next open ashtray, pull wood up from around shifter. Then the trim under the wood that goes around radio etc, pull that up and back starting at rear and remove. Be careful not to scratch wood. Now pull armrest box up and you will see a little black module there about half the size of a pack of cigarettes. Follow the harness to back of console and unplug it.
The components (last time someone quoted) were around $1,500.
Since then prices may be less... Try lookin for used components???
