Bluetooth/phone problems
Old 04-24-2013, 11:23 AM
Simon.h's Avatar
Default Bluetooth/phone problems
Hi all, I have a late 2002 3.0 V6 which has the touch screen sat nav/voice/blue tooth etc and its all been working fine up to a few days ago. The touch screen is on phone and acts like its in a middle of a phone call i.e the timer is counting the mins/sec. The phone screen also stays on then the engines turned off and then the car is locked. Also there is no sounds from cd/radio etc because it thinks the phones is in use.
Any ideas??
Old 04-24-2013, 12:25 PM
JagV8's Avatar
Received 4,533 Likes on 3,942 Posts
Disconnect battery?
Failing that try fuses & relays.
Next would be a dealer reset I suppose.
Congrats on a unique (as far as I know) problem!
Simon.h (04-25-2013)
Old 04-25-2013, 12:46 PM
Simon.h's Avatar
Cheers!
I the end I unplugged the blue tooth module under the armrest and plugged in back in and its working fine.
Its only does this if the car is parked with the sun on the touch screen for a good few hours.
Old 04-25-2013, 02:37 PM
JagV8's Avatar
Sounds a mite painful but any "fix" is better than none I suppose.
Old 05-04-2013, 02:31 PM
Simon.h's Avatar
Well I turned off the blue tooth on my phone but the car is still call from its phone book.
Old 05-04-2013, 02:33 PM
Simon.h's Avatar
Well had the same problem again. It only happens then the suns out and the inside of the car gets very hot!
Old 05-05-2013, 08:26 AM
JagV8's Avatar
Sadly it looks like it's just your car so I suppose a fault, maybe one you can live with.
Clamdigger
09-12-2015 03:43 PM
mcdutch
09-04-2015 03:38 AM
obwoodie
09-03-2015 07:45 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: Bluetooth/phone problems
