Boot Latch or Solenoid Not Working
Does this sound like a replacement latch is indicated? Upon depressing the release button on the keyfob, the boot latch make a rapid sound like the solenoid is locking/unlockinghowever it does not release.If I pressthe fob while simultaneously pressing and lifting the boot lid button then I canopen the boot.It still makes the rapidlocking/unlocking sound. This is theonly way to open it currently.
And, sometimes it will not latch upon closing and I need to simultaneously press the fob while closing the boot lid. The fuse #59 in the boot fuse box looks fineso I am thinking that the latch mechanism is worn or maladjusted.
I had a boot latch fail 6 months ago. Trunk would not latch closed.
Once I got a new latch replacement from the dealer I could feel the problem with old vs new latch assy. The defective one sounded and felt like it had internal gear teeth missing (something grinding) in the mechanism while manually cycling the open/closed position with a screwdriver; this after disconnecting from mounting location and cable.
The first new latch lasted 2 whole cycles after installing then failed to latch closed. Smelled burning electronics somewhere in the trunk area and figured it must be the new latch.
Dealer ordered second new latch at no cost and this one has worked fine with no problems for 6 months. Latch cost was approx $102. Not sure part you need is same but mine used P/N XR856390 8C
Happy wrenching!
Happy wrenching!
I treat it the same way as the gas door solenoid. Keep them both greased with white Lithium grease and hopefully you won't have any more problems.
I read about the plastic pin problems on the gas door years ago and started spraying it once in a while. I am still on the factory release pin and the gas door release still works fine.
