Bore Wash, I'm retarded
THANK YOU...I so appreciate this forum. I couldn't imagine what was wrong with my '98 XJ8 when it wouldn't start...after a cold start, short move, & shut off...NEVER AGAIN! I had no idea what was going on, until reading this forum. Evidently a typical problem. I followed the suggestions, & it is now running, just fine, thank you!! Decided to unplug the batter so it would clear out all those messages, & found a broken battery clamp. So change the oil & I'm back on the road...thank goodness. I love my Jag!!
Good to hear!
Thinking a bit more, once "enough" WOT cranking has been done, the car should start when you stop using WOT but not if you carry on using WOT. (Because WOT stops any more fuel being added so cranking gradually expels it. It can't start after that as there's no fuel!)
I suppose it still won't start if there's inadequate compression.
And "enough" is kinda hard to define
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
