Both banks lean P0172 and P0174 stalls at idle
I tried cleaning the mass air flow sensor twice, looked for a leak between the butterfly and the MAF, idle smoothes out when I spray carb cleaner under intake plenum on passenger side. Could it be a hose under there or the yellow oval plenum gaskets? maybe MAF bad?
drun (01-16-2012)
Got it back together last night and drove it around the block. No more vacuum leaks/codes, but now I have a leaking injector at the rail. I bought new o-rings but the parts place only had 2 packs of 4, so I just replaced the bottoms, (gambled and lost). It's raining today so tomorrow I'll get back in there to replace $5 worth of parts...
Kudos to you!
