Brake and ABS lights on when driving. No comp codes. Message about parking brake.
There are no codes ($1500 scanner was used). Is parking brake module attached to rear ECM? (right rear quarterpanel).
Which year to which year will fit 03?
I'll get it tomorrow from junk yard. Is itt a suspect? I had water in trrunk, but trunk seal looks OK.
Thanks.
PS. There is noise coming from radio area, is it parking brake motor?
Thanks.
Thanks.
Thanks.
the park brake motor is under the car so separate noise i would think .
no modules like water . you will want to remove your tail lights and re seal them before risking more damage .
I believe, I have bad ABS module (most likely), second suspect is brake module in trunk. I have another ABS module, I'll know in 20 min or so.
ABS and brake light stayed on ONLY when car is moving, so yesterday I checked codes while car was moving at idle speed, I guess 2 mph, there were no codes! It is definitely one of modules! Bosch ABS modules die all the time in all cars. We'll see.
In the other thread that you have open about the instrument cluster, you said the car had been standing for 8 months.
have you checked the battery as these faults can and do come up if the battery voltage is too low. It should be 12.6 v when fully charged.
charge over night and check the voltage after turning the lights for 3 mins.
Had much the same problem, and upon research, it seems that the battery was about to chuck it in and low voltage was likely the problem. The battery was the original, installed in 2002 and this was 2016 so I felt the battery had done it duty. Sure enough, the new battery results in no lights and everything operating as usual. So..... check your battery, cheap and useful.
JagV8 (05-09-2017)
Roger B
04-21-2016 12:57 PM
Roger B
04-14-2016 07:23 PM
badmojo
05-28-2007 11:16 AM
