Brake Booster/Master Cylinder(How to tell failure)
In a 2005 S-Type 3.0, how would one tell if there was trouble with the Master Cylinder or the Brake Booster. I know there is a fluid level sensor and a brake booster travel sensor that I assume would throw a warning and a code. I am also guessing that the DCM would not work properly and the ABS would cause an error. However I am not sure. So other than complete brake failure, how would someone know if there was a problem with either?
Tom in Dallas
2005 S-Type 3.0 65k
Tom in Dallas
2005 S-Type 3.0 65k
Received 2,259 Likes
No I do not have that problem. I had changed pads and rotors and got the new dimpled and slotted ones from brake performance / prem- semi-metallic and since then have had a mushy and more of a soft pedal than what is even normal for the S-types. I have another thread on this and if you are familiar with this, I would appreciate your opinion. I am now going one step at a time. Here is the link.
https://www.jaguarforums.com/forum/s...uestion-92205/
Tom in Dallas.
Tom in Dallas
Thanks again. these things can become quite frustrating.
Tom in Dallas
With the engine off, press the brake pedal several times with a short rest between each stroke. As the residual vacuum is used up, you'll feel the pedal getting hard. That's what a failed booster feels like.
I am just trying t solve my brake problem one step at a time. The majority of responses I have had, including yours on my other post, point to the pads or pad material. I think that Brake Performance uses centric, which is what I got.
I am going to try different ones on the front and see what happens.
Thanks once again
Tom in Dallas
Got it. I have a good working understanding and am very detailed, but am terribly limited by limited vocabulary in the field of car mechanics. Thanks goodness, I do not have that problem.
Thanks once again
Tom in Dallas
Thanks once again
Tom in Dallas
I just changed out my front rotors for upgraded slotted rotors - I use EBC pads - I noticed a difference also, but that difference was greater stopping power - shorter travel time to brake to a dead stop - no issues whatsoever with a soft, hard or traveling brake pedal after swapping out the rotors - look at the pads my friend...
Thanks again- I think that makes sense as well. Which EBC did you get?
Tom in Dallas
I drive in NJ (Turnpike/GSP) hard braking capital of the US and these pads are awesome and worth every $ spent!
1964Daimler
09-09-2015 11:28 AM
