brake booster vacuum line clip
Good luck!
Robert Page (06-03-2013)
My o ring for the vacuum line in the throttle body elbow needs replacing and my dealer says that the black plastic clip will break if they try to replace it, it sounds like the same problem that dtown was having. My dealers says that the part number C2S15816 is for an XType and will not fit my 2004 XJR because the plastic part is too small mine is bigger and Jaguar do not supply that kit for the XJR so it's new Elbow assembly needed at $1200. Now this plastic clip is separate from the Elbow so you must be able to get it surely. Any help would be greatly appreciated.
Good luck!
clubairth1
29
05-10-2024 12:57 PM
1964Daimler
09-09-2015 11:28 AM
