Brake calibration when replacing EPB module
Hi guys. Due to my longterm woes with the EPB I have decided to try one of the last things left for me which is to replace the EPB module in the trunk. I bought a second hand EPB module and replacing them seems very easy - it's just the two cables right? But do I need to do any preparations not to fry the replacement? Do I need to also calibrate anything in any specific way? Or can I just do the swap myself?
Just to point out, currently my car is always in Parkbrake fault mode - I can drive without issues, the park brake does not engage and the car doesn't beep.
Also just out of curiosity - what do the last two letters of part number mean, I have seen these modules with the same code except for the last two letters that were different in fairly similar cars.
Cheers,
Nerius
Cheers,
Nerius
I have found if you don't want additional problems. Get a used module that matches the EXACT part number. Not always but this can mean the difference between it working perfect to taking out additional items because it's made different.
I just did this on another car when I purchased a used FEM. There was about 3 different versions of the last two letters. I did not know what if anything was different so I got the one that matched.
FS[MidAtlantic]: Drive shaft cover plate
deelli
10-22-2015 11:09 PM
Chris Jenkins
10-22-2015 07:15 PM
Goncalo Proenca
10-20-2015 04:52 PM
