Brake Fault. iCarsoft says Left rear tone wheel?
One thing you can do is connect a battery charger while trying to start. This will help keep the voltage a bit higher than just a suspect battery alone. If all is good now, you know low voltage is the culprit.
Even if you do find your present battery is at fault, I think you're SOL getting the vendor to refund your money. They have their criteria for testing, and won't put much faith in what some guy on the internet tells ya.
ZenFly (01-12-2021)
Thanks Karl.. I'll get the sensor on thur-fri , install it and dump the codes like other side last yr.. If the transmission doesn't reset I'll have to take it to a trans shop that can program a 6HP26. I' understand there are a few other cars that use them. I think it's one of the most impressive parts of the car.
The following 4 users liked this post by ZenFly:
The following 2 users liked this post by joycesjag:
S-Type Owner (01-16-2021),
ZenFly (01-16-2021)
lbeagles
07-24-2014 05:45 PM
Cleanability
02-23-2013 08:06 PM
PerrysJag
02-19-2013 03:46 PM
