Brake Flush:
Received 2,263 Likes
Wuzupez (04-28-2014)
Yea be a bit careful as you don't want DOT 5 because that's Silicone brake fluid and outside of collector cars that sit a lot it's not that great of a brake fluid. Very bad about entrained air which leaves you with a soft or squishy brake pedal.
Plus it's NOT compatible with the normal brake fluids so it's usually recommended to flush the entire brake system with Alcohol to remove all traces of the non-Silicone fluid.
We do have DOT 5.1 now which would be fine for a full flush.
The following 2 users liked this post by Mikey:
JagV8 (04-28-2014),
Jumpin' Jag Flash (04-29-2014)
xjrjag
09-24-2015 10:08 PM
