brake lights stay on after replacing brake booster
Welcome to the forum dweidmann,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
We replaced the brake light switch and it is still throwing a code brake light switch fault. What the heck
Try this to reset the brake light switch , remove the switch from the car and pull the press pin out and it should extend a bit further ,
then refit it to the car and press the brake a few times to re set it's travel !
This is an x type fix but can't imagine thay would be mutch differant !
Also did you remove the code for it to return or could be code
For the previous switch ?
Fraser Mitchell
10-01-2015 04:06 AM
