Brake Pads
RE: Brake Pads
I just did my brakes last night. Took me 45 minutes to to the fronts.
Popped wheels off. Stuck screwdriver in the caliper hole and mushed the pad/piston back into the caliper. Got out the 12mm wrench and got the calipers off. Got out 15mm deep socket and had the calipers mounts off. Banged the disc off with my hand. New rotor on. Sprayed with brake claner. Put mount back on. Put new ceramic pads on. Greased back of them with copper. Slip caliper on. Wheel on.
Do other side.
Total cost? $40 a rotor. $109 for ceramic pads. $5 for brake cleaner. Had some copper about. 1 hour of my time and $200. Rears are just pads only and they were $90 for ceramics. I already have the wind in tool.. Lots of brake cleaner and copper left. They should be an hour too. Might do those Saturday morning.
Total cost of brakes all 'round excluding rear rototrs since they last nearly forever? $300. 2 hours of my time. Easy as pie. Next up is the front sway bar bushings. Those will be easy too.
Do other side.
RE: Brake Pads
Nothing like the feeling of DIY is there? That's why I love cars!! Did all 4r's on mine too! All the rotors were replaced just before I bought the car by the dealer but the stock Brembo pads were super dusty and noisy so off they went.
Now no more noise and no more dust for about 1 hour and 150.00.
RE: Brake Pads
Cosworth & Bad Mojo, could one of you swing by Dallas and give me a hand?
I think I read somewhere that the rear brakes required a special tool? Is that right? Cosworth - why not replace the rotors on the rear?
One mechanic I talked to called to find out the cost of the parts and he told me thery were expensive. He gave me the lowest quote and it was still high due to the parts. Is that becuase he is checking the cost of OEM?
It sounds like the brake job is pretty straight forward from your descriptions so it seems like I could buy the parts and get a decent mechanic to do the work for me. I changed pads once on an Alfa RomeroI owned but that was some 20 years ago!
RE: Brake Pads
Guess I'm going to end up doing them next weekend. Its a new month, and I can't get my parents to do it till the 18th. I don't know that the pads will last much longer, so it'll more than likely go metal to metal before then. But I HATE the shop out here on base where I work at. I need to stop putting it off. I mean, it won't be hard to go to Autozone and take an hour or two out of my day.
1964Daimler
09-09-2015 12:28 PM
