Brake pedal won't disengage shifter
I'm trying to shift my car out of park but when I step on the break I can't hear the shiftier disengage anymore. I at one point saw a tiny little bit of smoke come up from the shiftier. I have taken most of the center console apart as you can see. I need some advice. I've included pics of where I'm at now.
How do I fix this?
How do I take the center console apart more so that I can get to the shift linkage?
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
How do I fix this?
[IMG]
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/31935-brake-pedal-wont-disengage-shifter-imag0938_zpseb4ccf6f.jpg?dateline=1359686371)
[IMG]
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/31936-brake-pedal-wont-disengage-shifter-imag0937_zps3432d12f.jpg?dateline=1359686371)
[IMG]
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/31937-brake-pedal-wont-disengage-shifter-imag0936_zps1ba8f76c.jpg?dateline=1359686371)
[IMG]
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/31938-brake-pedal-wont-disengage-shifter-imag0935_zps97d711fb.jpg?dateline=1359686371)
[IMG]
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/31939-brake-pedal-wont-disengage-shifter-imag0934_zps2f52f2b1.jpg?dateline=1359686371)
[IMG]
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/31940-brake-pedal-wont-disengage-shifter-imag0933_zps53a25237.jpg?dateline=1359686371)
[IMG]
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/31941-brake-pedal-wont-disengage-shifter-imag0932_zps77a43b1c.jpg?dateline=1359686371)
Search on here will get you it - may even just be in the stickies as it's been explained a couple of times.
One thing to check first is the 2 bolts for the shift cable on the side of the trans. If loose (or dropped out!) you can get this problem. Access from under the car.
I did look this up in previous posts and could only find people with 2000-2002 models that were having this problem. My car is a 2003. Could it also have anything to do with my driving the car with parking break cable disengaged? (Long story don't ask)
Would that bolt explain the burning electrical smell and little puff of smoke that came from the sifter? I'm concerned that it is some sort of short.
Before it stopped working I would have to step on the pedal a few times and shift it out of gear at the right time to get it out. It was making the clicking noise like it was disengaging but then would lock right away. Kinda like if you were to step on the pedal and hold it for a while with out selecting a gear. Now it isn't making the clicking noise at the shifter.
From your description, certainly sounds like whatever electro mechanical solenoid drives the interlock switch in the shifter, was showing signs of failing, and subsequenly, died.
Not sure if its something you disassemble to replace, or if most people just buy a shifter assembly used?
Someone will probably chime in or search for problems related to this, i'm sure this has been covered somewhere,
Can anyone tell me how to remove the ashtray so that I can remove the shiftier assembly. I can't seem to get to the the two bolts that are under the ashtray.
[IMG]
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/31986-brake-pedal-wont-disengage-shifter-imag0938_zpseb4ccf6f.jpg?dateline=1359759764)
If there is another way to get to it I'm all ears
couple of questions. with ignition on what gear is illuminated on shfter assembly. If it is any other gear than park then the bolt has problably fallen out. If the P is illuminated then press brake with ignition on and see if the stop lamps come on if they don't then your brake switch is faulty. If the stop lamps come on then your problem would be shift interlock solenoid. which means shifter. the ashtray does not need to be removed. removed 2 screw covers and both screws and tilt ashtray up. then removed 4 T30 bolts. stick flat head screw driver on pass side of shifter and pry out on cable, should pop off. find green connector to shifter and disconnect. gently lift up. 1 small cable will be attached at bottom. be gentle with cable. can break and then you will have troubles.
[IMG]
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/32285-brake-pedal-wont-disengage-shifter-f432ee94-2391-4cf7-bcdf-9c27a54c4033_zpsd93f392a.jpg?dateline=1359921523)
Or perhaps you would rather have the entire shifter unit - less than $100 with shipping!
03 Jaguar s Type Shift Assembly | eBay
Candy's Kitty (02-05-2013)
I've the same problem with a 2002 S Type. It won't shift out of PARK when the brake pedal is pressed. I swapped out the entire J Gate assembly, but to no avail. So not the solenoid (I checked the one I removed by passing a 12v current between pins 9 and 13 on the green connector CA41). On investigation I found that no current reaches the solenoid. The Gear Interlock relay (in the rear power box, in the trunk) is clicking away happily when the brake is pressed, but it doesn't appear to be telling the solenoid about it! There is a connector CA14-12 indicated on the electric layout documentation, but can anyone tell me where this connector is located? It ISN'T the big green connector immediately behind the J Gate, but further back in the car. Any ideas?
I checked the brake lights were working, and that depressing the brake pedal causes the gear interlock relay to click. So it seems the signal is getting through to the relay, but not from there to the solenoid.
I admit I have not "assumed the position" to check the actual brake switch - I'm wondering if I mightn't do myself a serious injury!
PS. Apologies for the double posting. Still getting to grips with Forum etiquette! Determined to get to the bottom of this fault, like a dog with a bone is all!
