Brake rotor question
NO theyre not, no more random than thinking any Jaguar "R" model came with Brembo brake standard(they dont)
I would always measure, there is no rhyme or reason to what Jag does at times. I have over the years seen stuff on cars theyre not supposed to have, and others that were supposed to and don't
That said, you can always use 300mm disc on the 320 sized but not the other way around. Ive seen it done believe it or not...The outer pad misses the rotor by 20mm, when you look for material left youll see a nice big ridge on unused pad![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Funny thing is, no one has ever complained about the reduced braking or noticed
I guess the point of my question was, if you have 300mm rotors, and want to "upgrade" to 320mm, besides the actual rotors, what else do you need? The calipers and pads remain the same I assume, but what relocates the caliper to accomodate the larger rotor? A caliper carrier bracket or something?
George
George
HI,
good thread!
I need to change my Breaks! I need all rotors!
I want to order them, because I get them cheaper then my service garage..
I got an offer for ABS(name of the brand) rotors 320mm front and 286mm rear... I would get them + the pads for € 390 (about 530$)
do they fit my 2002 STR?
I somewhere read, it needs 355mm... I'm confused..![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
I also found this rotors! very cheap! all 4 Brembo max just € 180,-- can it be? Do they fit?
good thread!
#28
#30
#31
#32
#37
#39
