Brakes losing vacuum
When engine is at running temperature bakes initially work for a second, then pedal goes hard as if there is no vacum or power assist.seems to be ok when car is cold.has anyone any ideas please, as at present my mechanic is scratching his head, so im hoping to assist him in diagnosing problem.any help greatly appreciated🙂
The other possibility is a leak inside the servo, in which case it would need reconditioning or replacing. One way to check this is to pump the brake rapidly while the engine is running. If the engine goes to die, you have a fault in the servo. If the engine note changes only slightly it could be ok.
Try the above tests and please report back results for analysis.
The following 2 users liked this post by davidladewig:
joycesjag (02-18-2022),
S-Type Owner (02-18-2022)
lickahotskillet
01-03-2014 03:53 PM
