British Diagnostics jaguar cable and software
Hi,
I bought this after much searching as I thought it was the most genuine option, however since it arrived I've not used it as I was concerned about some things I'd read on here and another forum.
Can anyone recommend something better and actually provide a link to somewhere I can buy it, or at least let me know how they got on with this if they have it?
https://www.britishdiagnostics.co.uk/products/jaguar-land-rover-ids-sdd-v130-kit
SDD will only work on 05 model year cars (made from January 2004) and newer.
Before that you need to use the older IDS software. (SDD130 should switch back to IDS, but this can cause interface driver and firmware issues.)
I use SDD-130 and a mongoose interface on my 05 model year STR.
However, this does need to run on a Windows XP computer that is not connected to the internet and re-sets the date each time it is turned on!
One way to do this is to run it in a virtual machine on a later laptop PC.
See this link for more info and some download links:
https://www.jaguarforum.com/threads/...nstall.108460/
One other thing to note is that if you do any re-programming or updating using the Jaguar software you need to have a powerful 13.8v power supply connected to your battery.
I use a 30amp variable voltage stabilised power supply. (Jaguar recommend 35amp) This is to stop the battery voltage dropping when using the software that requires the ignition to be on when in use. If the voltage drops too far the programming will stop mid-way and this can damage the modules you are programming.
A 5 amp battery charger will not be up to the job as it needs to power all the electrical systems on the car.
A simple rule to follow regarding re-programming and updating modules is that if it aint broke do not try and fix it!! Only do what you have to.
Mellow
Mellow
JAGUAR S-TYPE XS TD 2.7L (10-06-2022)
Mellow
Mellow
Below is the issue I'm trying to diagnose, hopefully this doesn't need me to get an external power supply but let me know your thoughts, thanks.
https://www.jaguarforums.com/forum/s...2/#post2573635
With SDD, as the name ‘Symptom Driven Diagnosis’ suggests you can find the fault by entering the symptom you have.
It will give you a list of the faults that are causing the issue with a % rating.
It will also give you a bit more info as to what to do next.
However, the workshop manual has all the specific pin point tests for eack fault code.
Here is a link:
http://jagrepair.com/images/AutoRepa...M-Workshop.pdf
Here is a link:
JAGUAR S-TYPE XS TD 2.7L (10-10-2022)
gijoe50000
07-09-2024 11:13 AM
KarlC
08-19-2013 06:33 PM
