Broke something already :(
In my hurry to finish installing a new K & N filter along with the removal of the "trap door" on the side of the air box I pushed down on the top of the air box lid and broke the 2 plastic clips that hold the top to the bottom.
Looking for your thoughts on a remedy for this, I like the sound of the R now as it is a little louder but I will need to do something because to box has duct tape holding it together.
Received 2,195 Likes
Yet another reason for the DIYers to remove the 1- 13mm nut and loosen the intake tube clamp, pull air box and change filter. Expensive lesson.
try www.car-parts.com for a used one.
www.junkyarddog.com works good too.
Give them an email address you dont use much though cause some of the guys really are persistent about their parts.
Take care,
George
Take care,
George
Oh, BTW... +1 on the car-parts.com reference... and no angry e-mails..
Wow......You guys are fast and with some great ideas thanks very much, I do like the idea of a used air box because the factory one seems to work well , there is something I like about a quiet car that hauls azz.
Just found the info page pertaining to the Mafioso Intake and I want to hear from a couple of members first on any extra HP or additional noise that may also be part of the new intake.
Does anyone have a aftermarket air box idea that I can compare the stock one up against.
Thanks Ya'll
Thanks Ya'll
Take care,
George
Thanks for helping with this topic, first question is : do you know of a aftermarket air box that will line up with your new elbow ; second question. Mated to a stock air box is their a "noticable" sound increase of the supercharger when the new intake elbow is installed ?
Sorry all if the questions have been previously answered.
Cheers,
Scott
The baffle door on the bottom of the box on opens during WOT. Giving an extra volume of air in the box. Without it fresh is constantly being fed in at the expense of a dirtier filter faster.
If you watch paleriders video the blower can't be much meaner with out actual blower work. Aka closing off the silencing reciculating chambers.
The Mafioso intake brightens up the supercharger wine nicely. Not at all annoying, actually pretty intoxicating with the windows down. Love it.
IMHO I wouldn't **** around with some aftermarket box. You need the MAF hookup to be correctly mounted and the spacing is kinda tight. Get a used box from one of the places mentioned earlier or I've had good luck with Motorcars LTD for used stuff in the past.
Or you could try to DIY some type of fastners on each half of the box to make a new connection. You'd want to take the whole thing out to work on it. Be creative and you can probably get something to work. You need an absolutely complete seal, no unfiltered air intrustion above the filter.
Thankfully I was informed by the members here to go and purchase a scan tool for $40 bucks so I can check and re-set my own cel lights.
