Broken HID lights
These links point to different solutions:
https://www.jaguarforums.com/m_43066..._3/key_/tm.htm
https://www.jaguarforums.com/m_36713/tm.htm
You can also block the movement of the headlight internals with the plastic hose which is on top of the assembly by fitting it inside.
I repaired mine with the aluminium block, they were fixed position unitl now but recently Jag have cleared the error fault on the motors and it works perfect.
Herve
Herve
Guest
Posts: n/a
Guest
Posts: n/a
Thanks Again. $3 in parts, twenty minutes labor, $2000 saved. And the car just passed NJ inspection.
I used nylon instead of brass bolts, easier tocut to lengthand tapped the holeso that I could properly thread the bolt into the unit. Also used a nut to tighten everything down.
Same problem here. The little ball was broken off of the leveling slide. I took the lens off of the assembly and made a new piece out of nylon exactly like the old one. Everything works just like stock except I'm sure it will last way longer!! Headlights are not covered by the SE warranty. I called Jaguar.
rsa760041
23
09-25-2015 01:33 PM
