Built-in Bluetooth Phone
I am trying to install a Parrot, through the radio Bluetooth phone connection in my 2004 S-Type R. It has the factory Navigation and standard radio, and I need to get the radio out to plug the Bluetooth module into the back. How do I get the radio out? There doesn't seem to be any fasteners visible.
you have to remove the cubby box.. lift armrest.. and remove cupholder and tray.. then remove 2 torxs.. then take out cubby box.. then remove radio surround by pulling outwardwith a good grip.. then remove radio .. with 4 screws . becareful not to scratch your astray cover..
If you go to www.nicestuffonline.com there is a harness available to direct plug into the bluetooth phone connector under the cubby hole and the parrot unit. Then no need to pull radio and will mute audio when call comes in etc. Is a nice setup.
