Buying air filter
Hello everyone. First off this could be my first or maybe not mod to the car if anything on buying a air filter for my STR.
I am aware and yes I have looked everywhere on this forum but still debating if I should go OEM or K&N filter. I want feedback from STR owners (or non STR owners) with their experience with K&N filter
OEM - well its nothing going on there just stock part #aj8-2766
K&N - I read on here it will create issues with the sensor and read about creating low end torque on s types and XJ's as well but read good reviews on it. part #33-2273
I was going to buy the K&N but after reading all the threads its a 50/50 on which I should get but whatever i choose I need a filter regardless.
Not the hardest thread to answer so some help and info would be nice. Thank you guys
Received 2,263 Likes
Using K&N flat panel in the stock airbox since about a week after I got the STR a few years ago. No problems at all. Washed and re-oiled a few times already, again no issues. I use K&N on all my vehicles, which just over the last 4 or 5 years has been a dozen or so, some FIPK kits, some just flat panel OEM sized replacements (like in the STR), and have yet to have a MAF issue, sensor issue, or any issue at all related to the K&N and the oil on the filter.
Follow the instructions for cleaning and oiling and you will be just fine. Don't overdo it on the oil, and you'd really have to saturate the heck out if it to possibly cause a problem in my mind. Just follow the instructions and they are easy to use, last a long time, and to me a good value.
I hope that quells any fears you had about using a K&N in your STR.
Glockjag (06-11-2013)
Don't believe the stories about performance increase- there's zero at part throttle and only single digit differences at WOT, if any.
Actually it is a relieve!!!!! sometimes im so indecisive for the smallest things and especially being my first mod.
I've used K&N before on my old car (except my old 3.0) but I know how delicate our STR's are with just a minor adjustment.
Yes that's the issue I've been reading about the oil cleaning so Ill be fully aware of it.
Well at least have a upgraded filter would be nice if I don't feel the difference in performance, its not I am expecting my supercharger to turn into a monster when I install a filter and run 10's on the strip!!!! But thanks
Hey Michael, 2 questions:
1) what are you using to log data?
2). It's my understanding that the Mina setup brings cold air from behind the headlight while moving, is this true based on your data?
Being that the Mina cone filter is approx twice the size of the standard panel filter by surface area, I wonder if there is a trade off for daily driving under non boost where it looses power compared to spirited driving where the offset of more air, albeit possibly warmer air gives more power under light boost?
I have an elm scan tool using Torque to monitor air temps. Once I am driving for a few mins the air temp does go down to ambient, but as soon as I sit at a light, it will shoot up pretty quickly. I am thinking it is still sucking in hot air from the engine bay.
It does *kinda*
I'll have to take some pictures when I get home, but it doesn't seal off hot air from getting to the filter. There is a hole directly beneath the filter as well as pulling in air from behind the headlight. Also!!!! The MAF tube is actually smaller on the Mina one
The big difference is that something like the Roush CAI looks like this:
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/45319-buying-air-filter-402099_385x270.jpg?dateline=1371135614)
And the Mina is just a wall
It does *kinda*
![](https://www.jaguarforums.com/forum/attachments/s-type-s-type-r-supercharged-v8-x200-15/45320-buying-air-filter-jag_s-type_performance_intake.jpg?dateline=1371135614)
[QUOTE=Michael Star;753733]I have an elm scan tool using Torque to monitor air temps. Once I am driving for a few mins the air temp does go down to ambient, but as soon as I sit at a light, it will shoot up pretty quickly. I am thinking it is still sucking in hot air from the engine bay.
It does *kinda*
Michael, I already bought the K&N. I never paid any attention to it being said of all the threads I have read about negative feedback from people with the Mina intake so now I am a bit confusing.
It does *kinda*
