Buying an S-Type V6 3.0 next week. some issues, help needed
Hello,
This is my first post so please bear with me in case it is not as it should be (hopefully I posted it at the correct place).
I will probably purchase a 2002 facelift model S-Type next week which was imported from the UK to Sweden, and has full service history etc since new. The Swedish MOT company however complained regarding a few issues.
I am wondering what these issues might be caused by, and how I can fix them (I am quite competent in fixing cars).
The complaints were the following:
Fault code (from the swedish mot company, so not the p.... code) 8.2.1.1. Fault in engine electronics "warns for fault in the system"
Lambda value "too high idle"
The owner tells me that he has fixed the issue before, but that it has come up again, he said that last time it was related to the spark plugs (sounds too easy to me).
Any insight in what this might be would be greatly appreciated.
Everything else seems wonderful regarding the car. No rust etc.
I will bring my OBDII reader when I go to see the car next week.
Kind regards, Karolina
AnOldSType (09-29-2019)
Okay, I asked the seller for the codes. Otherwhise I will get them with my OBD reader.
Yes I have changed timing belts, coils, spark plugs,etc.. cleaned carburettors and such things without any issues My significant other even complains about the amount of tools which I buy (our storage is full to the brim)
I always change my own oil + filter /fuel filter etc.
You need a laptop running xp service pack3 or windows7 32 bit.....the software can be purchased on ebay....usually sdd version 130 or 131 works the best,....the major item is the vehicle interface....most use a mongoose JLR clone like i do....click on my username and then threads started by me.....look for sdd purchase and read through it....,i have a few sdd versions on my google drive i could share with you if you decide to move forward with sdd
Jaaglady (09-07-2019)
Post the codes and there will be answers.....one of the main ones for a no drive is related to the cat converters..,..it will also have the check engine light flashing.....either way someone will definitely help you out
It give a whole new dynamic to the thread! Nothing else to report. Just thought id ket you all know that!
Pumpy
04-28-2015 03:57 AM
silly_me
10-07-2012 02:05 PM
lovelylellops
07-20-2012 07:27 AM
EuroCarFan1105
07-02-2007 07:14 PM
