Buying a STR 2moro
Old 09-27-2010, 06:18 PM
bdelgros's Avatar
Default Buying a STR 2moro
It has 71,000 miles. What are some of the things I should look for before buying. It has an excellent repair record (carfax) only thing that has been replaced was A/C pump. However owner says that when starting up cold the tranny has a hard time finding gears, but after its warm it goes away. That is all that worries me.
Old 09-27-2010, 06:43 PM
Mafioso's Avatar
Congrats!
find out if the TCM has been flashed on it.
Old 09-27-2010, 06:44 PM
marc4sgr's Avatar
I'll assume its 2003 or so..
if so be worried about that "small" transmission issue.
Old 09-27-2010, 07:06 PM
JOsworth's Avatar
Ummm... Test it well... Get it inspected... All STR's have a ZF 6hp26 box..These are really tough transmissions... There are some software issues that may seem like transmission issues.
That said.. Before you buy it you should probably get it inspected by a dealer who knows the difference between a software issue vs. a trans issue. The ZF box is REALLY expensive if it ever needs replaced...Hate to see you buy it then get hit with a $5,000 transmission job...
Old 09-27-2010, 07:12 PM
pdr1966's Avatar
Default chime in
I'll contribute: Look to see if the throttle body coolant line has been replaced - goes under the S/C and is the best part of a $1000 repair and seams to be very common.
Check that the key fobs work.
Test the transmission, specifically around 35-45 MPH in a tall gear for the torque converter locking and releasing under very light or steady throttle.
My input....
Pete
Old 09-27-2010, 07:21 PM
bdelgros's Avatar
It is and 03 offered 11k. So for that price I can expect some problems. 2nd owner car.
Old 09-27-2010, 07:22 PM
Mafioso's Avatar
oh yea and the most important part.... GET A WARRANTY!!
Old 09-27-2010, 07:27 PM
bdelgros's Avatar
Buying from and individual seller, no warranty.
Old 09-27-2010, 08:11 PM
fergs03R's Avatar
carfax and the like only shows so much...before I bought mine, I took the VIN to my local Jag dealer and had them pull the entire service record, I was fortunate, the service mngrs comment was"wow, the previous owner was obsessed", it had every thing possible service done on time, and had every software revison, and any and all recalls/tsb's completed..I got the printout as well.
Its a worth doing.
Old 09-28-2010, 09:39 AM
Mafioso's Avatar
That doesnt matter if you want I can PM you my warranty companys info.
Its pretty comprehensive and reasonable.
My 02 had 80k miles and they covered it for 100K miles and the only non covered items were, User serviceable items- Oil change, brake pads (rotors calipers covered) and other scheduled maint. and interior plastics IE ashtray cupholders.
Old 10-02-2010, 06:23 PM
bdelgros's Avatar
Car is immaculate!!! Drives great, now just need all the right info for taking care of it, inside and out.
Old 10-02-2010, 07:17 PM
vance580's Avatar
You should start by throwing up some pics.
Old 10-03-2010, 06:53 AM
Enthusiast's Avatar
Agreed.
Old 10-04-2010, 10:13 AM
Mafioso's Avatar
Old 10-05-2010, 06:21 AM
jya's Avatar
jya
jya is offline
Min STR had an excellent full 1 owner history as well as very low milaege (39,000km when purchased in 2008) but both rear lwr. wishbone hydro/rubber mounts were cracked and leaking (unroadworthy), as well as the front forward lwr. wishbone hydro/rubber mounts!
I was fortunate to obtain all 4 in excellent used condition (approx $800 US), here in Australia.
Have to buy whole arms as cannot buy hydro bushes seperately!
In all fairness to the car the number of speed humps we have here in Melbourne are a joke!
Otherwise car is incredibly reliable!
enjoy
Old 10-05-2010, 06:43 AM
Jon89's Avatar
Received 4,369 Likes on 2,857 Posts
jya,
Tell me about your Triumph Stag. I've always admired the looks and power of that car. Haven't seen one in 20 years or more....
Old 10-05-2010, 07:18 AM
jya's Avatar
jya
jya is offline
Originally Posted by Jon89
jya,
Now you got me started Jon89!
I will try not to bore you too much.
Had the car since '92 and cannot part with it. Great convertable 4 seater and a lovely 70s V8 rumble. Not heaps of power (120kw),as 3 litre OHC V8 quite understressed from factory but quite tunable as plenty of high quality specific parts available.
Italian designer Michelotti penned the looks but Triumph hastily introduced to market which led to some poor quality em.... read 70s British Leyland... engine issues. Mostly related to the usual English overheating, gasket blowing, inadequate radiator problems.
Out of a production run of about 26,000, roughly 20,000 stayed in the UK. The most popular export market was Australia. And the engine never appeared in any other British Leyland product.
Although nothing inherently wrong with the engine design, the high mounted water pump in the V meant that if water level dropped, no water circulating.
With excellent parts avilability, no more reliability issues, 4 seats, independant suspension, pwr steer, electric windows, air con, wool carpets, real timber, dual circuit front disc brakes etc. etc. and a heap of passionate owners the cars are highly desirable. Values have also been creeping up of late.
Buy one now before they get to E Type prices!
Cheers John
Old 10-05-2010, 07:38 AM
Jon89's Avatar
Thanks for the reply. I'm far too tall for a Stag, but I really admired them back in the 1970s and 80s. Keep on enjoying yours....
Old 10-05-2010, 08:57 AM
JagV8's Avatar
Received 4,533 Likes on 3,942 Posts
enjoy
If you need more, see "The definitive wishbone bush thread" here http://www.jaguarforum.co.uk/viewtopic.php?f=16&t=34593
Old 10-06-2010, 09:03 AM
bdelgros's Avatar
I need some help in car of the vehicle.
1. Whats best for the leather, and how often do I treat it?
2. What oil should I use, seeing how I live in Pa, its a little colder?
3. What type of treatments should I use on the dash, tires, wheels?
4. I am using Eagle one nano spray wax right now, any other products would be appreciated.
Quick Reply: Buying a STR 2moro
