A/C blowing hot and cold at the same time
hot air is coming from the outside vents and semi cold air comes from the center vents. any clues to why its doing that? replaced compressor and dryer and expansion valve a month ago. help please
2003 S-Type V8 4.2L
2003 S-Type V8 4.2L
The easy answer is that your DCCV is not fully closing on at least one side. This could be due to corrosion, debris, or mechanical failure of the valve, or a failure in the climate control board or wiring between the two.
However, you should execute Karl's excellent Climate control diagnostic in a systematic manner to be sure. I think it is still on the front page here, somewhere. If not it is certainly in the top 5 pages of threads, if not already in the stickies. Here you go, found it for ya: https://www.jaguarforums.com/forum/s...ol-how-185002/
None of the above apply if you don't have an S-Type (X200/202) and no one can tell from your post what you have. Please add a signature containing the Model year/engine/gearbox of your car so people can formulate more accurate and useful responses.
jdsjds3030 (08-01-2017)
