a/c heater blower with mind of its own
Twice now I have approaced my '03 s type to find the a/c heater blower motor running to beat the band. Windows are up everything is turned off. The other day it happened while I was in the car with the drivers window down and no key in the ignition. What's this? Don
Just to check - it's definitely the a/c blower? Not by any chance the engine cooling fan?
Would the engine have been cold (i.e. some hours since car last used) on any of the occasions it's happened?
If it happens again when the key's not in the ignition, see if you can operate any of the things ithat should need it in the ignition. (To help figure out if it's an ignition lock/etc problem.)
Mine does this too...
You're not alone Don. Mine does the same thing. It's definitely not the cooling fan. I'll come home, park the car in the garage, go out to the garage anywhere from 30 minutes to an hour later and find the interior blower going at full speed. Key's been out of the ignition the entire time. If I re-insert the key, turn it to the position just before the starter engages (i.e. enough to bring up the radio and everything else) and then turn the ignition back to off and take out the key, the fan will stop. Of course it could be coming on again after I go back inside... haven't cared enough to babysit it that closely. I've noticed it doing this at least 15 times over the past two years.
If anyone has any ideas, I'd love to hear them.
Bob
Bob
yeffots (05-19-2014)
Hi, the same thing happened yesterday to my 2006 STR. I was working in the garage at night and all of a sudden my blower fan went on. I was thinking this might be a feature to get rid of moisture from the system, but I cannot find info on that.
Has anyone rectified this on their cars?
thanks,
Frank
thanks,
Frank
2005 s type R blower fan wont shut off
I just encountered this problem with my 2005 s type R where the interior blower fan is running every time I go back to the car after shutting it off. When I turn the key to the right to engage the radio etc it shuts off. Has anyone found a solution to this problem. I am concerned that this is kill my battery. Thanks
