C1285 Brake booster solenoid output 0
Old 08-02-2022 | 03:10 PM
p3x935's Avatar
Default C1285 Brake booster solenoid output 0
Greetings,
I have a 2003 S-type R, US spec.
I am getting an intermittent ABS DTC fault c1285 (brake booster solenoid output is zero.)
I have verified that the wheel sensors are working and with a scan tool that the value of the solenoid output is zero.
Sometimes if I restart the car, it goes away. Other times its locked in for days. Doesn't seem to be much pattern to it,
I need some expert guidance here. I am looking for the vacuum routing for the brake booster and perhaps any insight y'all can share.
Thank you all
Old 08-02-2022 | 03:30 PM
Joedotcom's Avatar
hi
servo solenoid faulty, or wiring open circuit or short to earth
code description cant be any clearer
cheers
Joe
Old 08-03-2022 | 10:33 AM
motorcarman's Avatar
Wheel speed sensors have nothing to do with the brake booster.
Active booster has a fault.
File Type: pdf
M90power
05-31-2015 03:57 PM
denraden1
05-09-2013 09:11 AM
daboss085
09-04-2012 01:27 PM
daboss085
08-22-2012 06:03 AM
Quick Reply: C1285 Brake booster solenoid output 0
