camshaft timing help
Old 04-04-2016 | 04:55 PM
Gil's Avatar
Gil
Now that was embarrassing!!!
Tired, momentary lapse!
Old 04-05-2016 | 07:50 PM
Gil's Avatar
Gil
Default Test Cam Advance?
Well if any one is out there?
Is there any way to test the intake cam advance? I picked up a protractor, and very, very carefully checked the cam timing. I sure looks dead on. I am now unsure if I was off originally. I did my best to test it with the timing cover on, and then of course tried to shift it. Well now in some quick testing and my repetition of the compression test, it still looks like bank one is charging up pressure quicker and higher than bank 2.
Oil shot everywhere, so I need to put some sheet metal on and re try my compression. It still was so strange to have one bank so different, and have the engine run and idle so nice.
As this was a pita, I just was concerned to check all I could before reassembly.
any thoughts?
Old 04-05-2016 | 10:53 PM
NBCat's Avatar
As mentioned earlier, use the special service tools to reset the camshafts for correct timing.
Refer to JTIS or the Workshop Manual for correct procedure to set up the VVT solenoids when installing the primary timing chains.
abonano (04-06-2016)
Old 04-07-2016 | 04:57 AM
Gil's Avatar
Gil
Honestly, having done that, I was curious if there was any way to test their proper function. as something is causing a compression variation from one bank to the other.
Old 04-07-2016 | 10:07 AM
joesoap's Avatar
Check you have valve clearance on the valves on the bank that is lower its losing compression somewhere?
Which could be cam phasing but valves are easier to check, with engine cover stripped.
Stamford
03-26-2016 05:07 PM
dogsoup
03-04-2016 07:33 AM
Alan Stoldt
03-03-2016 05:06 AM
64vette
Non-Jaguar Vehicles
02-29-2016 08:03 PM
TexMurphy
02-29-2016 01:04 PM
Quick Reply: camshaft timing help
