CAN I USE SYNTHETIC OIL ON MY S-TYPE R ? DIY OIL CHANGES INFO NEEDED. THANKS
Guest
Posts: n/a
Im new to Jaguar, I owned Mercedes all the time so I am familiarized with the procedure of oil changes. I have an S-TypeR so I need help.I did them every 10,000 miles with Mobile One Synthetic Oil. Can I use this with the Jag every 10,000 miles ? They say Synthetic Oil is better for the S-Type R engine is this true ? Some people say with a Jag you must change it every 3K to 5K miles is this true ? What method do you do ? Also I like DIY instead of paying lots of money at the ***********. I normally use an Oil Extractor, put it in the dip stick tunnel, and suck it out. Its fast and easy. Then put a new filter in. Can I do this with my Jag ? Help me out. Thanks
Does the "R's" supercharger use the same oil as the engine or does it hold its own oil like GM's superchargers on the 3800 V6s? If the super has its own oil good conventional oil should be fine for you, your change interval is/should be determeined completely by your driving habits...lots of short trips/around town driving? Go with 3mos/3,000 miles. Lots of long high way driving or a commute that puts more than say 65% of your total driving at high/steady state speeds? You could easily push the interval to 5-6000 miles with conventional.
If you driving habits are like the first scenario just stick with conventional, if you're like the second scenario you could go with synthetic and probably change once a year.
Do you have the manual foryour S-Type R? I have a 2003 S-Type V8, not an "R". My manual states to use synthetic oil every 10,000 miles or 12 months which ever comes first.
The mechanic shop I use specializes in Jaguar and Land Rovers. They told me they recommend regular oil but I stuck to the manual and used the synthetic (Castrol). I know a lot of people have opinons on synthetic and which ones are truly syn. Also, I have been told to change the oil more often, but the manual states what it states! I'm not opposed to doing it every 6 months as I do not drive many miles. But before doing that I need to do it myself because the shop charged $125.00 to change the oil!
The local quick oil change place where I take my wife's Nissan Quest will do the Jag for $90 using Royal Purple Oil.
If you want to learn way too much about oil, check out this site: http://www.bobistheoilguy.com/
Synthetic oils are generally better. The rule of the tumb is that you switch over to synthetics once your engine is broke in. If your engine has high mileage, I would try a synthethic blend. This is do to the fact that engines with high mileage tend to have wore seals that may leak and or the engine mayburn oil.
ORIGINAL: momo
ORIGINAL: reddrawf
Momo, does that apply to all vehicles? I have a Nissan Frontier Pickup (2000) with 53K. I was thinking of going to synthetic on the next oil change.
ORIGINAL: momo
2) You can switch to synthetic (and back to conventional) any time in your vehicle's lifetime. You'll only have worn/leaky seals if you have a poorly maintained engine; there are a couple of "high mileage" synthetics that you could use in an engine if you experience weaping or leaky seals after a change to synthetic. Synthetics don't "cause" leaks.
reddrawf,
I would switch to synthetic if your driving habitsallow you to take advantage of synthetic's extended drain intervals. Amsoil, Pennzoil Platinum, Valvoline or Mobil 1 all offer great protection and when coupled with a high quality filter should let you do annual oil changes depending on your driving habits and mileage.
odds (01-11-2013)
Gerard Radimaker
09-13-2015 10:33 AM
