cant refill fuel tank
hello cant find a similar thread. so hope someone can throw light on this.
S type year 2000 v6 3.0 auto petrol.
stood the car down to do a full over hall bearings, suspension, brakes and such like. did a gearbox oil change and full service. all fine. only problem since reconnecting battery I have to fill the tank very slowly or the pump auto shut off occurs. taking about 1/2 hr to fill the tank. runs beautiful when filled so a bit confused. car was stood for about three months and did put a galloon in via a mobile gallon fuel holder at home. did also change the fuel filter during full overhaul.
Am considering depressurising tank but not sure any ideas. thanks in advance..
Thanks for replies.
Yes I found the thread that suggested using other refuelling stations and have tried this.
It still takes an age to refuel. and the 1/2 hour to fill drives me potty so Ive researched the purge valve and thinknkg bwst to depressurise and take a look at this valve.
any tips would be greatly appreciated.
Thanks for replies.
once you have taken the petrol cap of the tank there is no way that it is a sealed system or under any form of pressure at the filler cap. Have you looked to see if the butterfly valve is for rotating correctly letting the petrol stations pump in so there is no back pressure causing the pump to cut out due to too much petrol going into a reduced area.
thanks Ducmon will give this a try and come back.
hello
I hope all are well.
I have tried all of the above over a sustained period of time and nothing seems to improve the situation. I have now pushed a flexible pipe cleaner down into fuel pipe. the first thing it pushes is a small flap just inside which moves easily, but as the flexi pipe moves down it encounters another flap which is stiff and only opens with a moderate amount of force.
Is this the butterfly cap mentioned?
any advice to loosen up would be appreciated?
Finally would I be better off replacing the whole fuel filler pipe?
I have one of these and the light on the end gets pretty hot, so I would not put it in the tank.
jag43v8man
04-17-2008 04:50 PM
