Car acting weird when it starts
Hey guys!,
Well when I start my car, in the morning cold weather, it kind of pulsates (my engine speed) the tach jumps around. after like 5-10 minutes everything is fine.. any idea on what might be happening?
This never happened last winter.
Please LMK
Thanks,
Paul
stype1990@aol.com
Please LMK
Thanks,
Paul
stype1990@aol.com
RE: Car acting weird when it starts
I got a feeling you all need IMT seals and a breather hose. You can spray throttle cleaner on the IMT valves when car is at idle and see if idle changes. If it does, change the seals. Also the same with the breather hose. There is a post I will try and link it
Hmmm I cant find it. There was a post with great pics of the IMT valves and breather. Sorry. It is there somewhere.
Well I just noticed that this thread is on S-types, but everyone that replied had X-Types.
Anyway, The IMT seals leak on S-Types too so these are the pics.
http://i265.photobucket.com/albums/i...tishsg/044.jpg
http://i265.photobucket.com/albums/i...tishsg/045.jpg
If you talking of high idle at first start, it is pretty normal for any of the 4.2 v8.
therecis software update for ECM but on cold start the idle can go as high as 2000 rpm
before mellowing out. If you have different problem, repost and I will let you know.
Cool I'll check those seals and see if thats it... and I own an S Type.... it was -5F this morning,the engine was bucking away in the warm up about 2 to 3 minutes it stopped.... so i decided to take my back up, well then it was jealous of the Jag so the heater was not blowing hot air, I think my water pump is out.. dam you00 Stratus
This is on cold start. It starts at 1150 rpm and goes down to 900 after about 20 sec's. Then it takes about 4 min. to slowley creep down to 750 rpm. It will pretty much stay there for a long time until I start driving. If I stop and put it in neutral it is at about 600 to 650 which I believe is about normal. However if I let it sit for awhile even though the engine is still warm it again takes a long time to go back down to the resting idle .
Yea, the dealer told me about the software not being up to date and said that even though it is causing the car to not operate properly that updates are not covered by SE. They told me it would be 250.00 for updates. I called SE and they told me the same thing. I think that as long as a car in under warranty all software updates should be covered. Just my opinion.
BrentGardner
28
04-26-2024 03:08 AM
1964Daimler
09-02-2015 11:41 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
