I have 2000 S-Type 4.0L and it has a slight cough when it idles only when its warm. It also smells like its running a little rich. My mechanic pulled codes and we got a CAT converter code. We came to the brief conclusion that its most likely a bad upstream 02 sensor. Has anyone else experienced this?
Both my V6 cars did that. The Black worse than the Silver.
New coils fixed it all.
Same basic coil over princple, just you got 2 more cylinders.
O2 sensors, mainly PreCAT, are a service item. Not many bother until they go AWOL, but NGK (NTK), and Bosch, recommend 100K miles as a change out point.
Thats good to hear!
I believe 6 of the coils have been replaced recently .. would it be too tough to change the last 2 on my own or should i have a pro do it? what does it require?
I hope you have a good independent mechanic who knows Jaguars, and will keep you from chasing ghosts.
This forum is rich in info on 1st generation S-Types. Coil on Plug failure is common for just about every car. 4.0 has 8 possible fail points. Why did they stop at 6? Scanner will tell you which one they didn't- likely the culprit. Read the threads about the 4.0 here. These will help you keep that cat running like it looks!
Reason: Spell Check
Definitely related to a failing or failed coil(s) I would also recommend double checking the replaced coils if they are not OEM... Aftermarket coils are not highly regarded...
Yes, my 2000 S Type coughs at idle only when I reach operating Temp. I also feel the same cough / stuttering at about 45 mph . Other than that the car runs great .. ( it also seems to be drinking more gas than usual)
