Car seems to surge when going uphill...
I have a 2004 S-Type with 34,000 miles on it. It seems like whenever I start to go up a hill it tends to have a sight surge to it (slight lurching forward and backward). Is this a common issue or is there something I am missing and an issue that needs to be fixed?
- Russell
- Russell
Unfortunately it's a very common problem and there's a 95% chance that it's your converter going bad.. It will get worse and worse until one day the car won't move.. My recommendation is that if you don't already have a warranty go buy one now because they all have a 15-45 day starting period where you can't file a claim... Eric
So this defect involves both the ZF 5-speed and the ZF 6-speed transmissions and is a common problem? I thought these ZF transmissions were virtually bulletproof and a major upgrade from the old Ford transmissions in the early S-Types. What happened? Are the torque converters too flimsy to handle the weight of the vehicle? Do they gum up with debris? So much for the $60-per-litre Shell ATF mineral oil being the magic lubricant that solves all the transmission issues....
The transmission in our 2000 4.0 SType failed around 60k. I don't recall the surge going uphill leading up to the problem. So maybe the new transmission's have a different point of failure? I certainly haven't read about many people with newer models having failed transmissions but maybe the miles aren't enough to know yet.
What I do remember however was a smell whenever we would drive up a steep hill. I always suspected something in the transmission. Eventually it did what STR says....just decided it wasn't going to leave our driveway.
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
