Car stuck in park
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
i am just going to get straight into the point. so my 2005 jaguar s type r for some reason it is stuck in park but my shifter is stuck when try and put it park but it says its in park but i can move the sifter into drive and reverse and neutral but it wont actually put it into neutral or drive or anything else. also my key is stuck in the ignition. also is there way you can put a s type into neutral without the shiftier working
Inspect the two mounting bolts where the shift cable attaches to the transmission. These two bolts are notorious for backing out and causing the exact symptoms you have. Details in this service bulletin:
http://jagrepair.com/images/TSB/TSB2...h%20J-Gate.pdf
S-Type Owner (06-09-2022)
The following 3 users liked this post by Sportston:
chaddm55
22
05-30-2019 04:15 PM
Rlover
03-30-2016 10:04 PM
