Car Will Not Start!
Old 03-11-2015, 03:24 PM
car5car's Avatar
Old 03-11-2015, 10:07 PM
Jimmy 68's Avatar
Originally Posted by JagV8
Good to know! Makes sense, too
Thank you, Sir!
Very interesting, the suspense was killing me, but at least she's back on the road!
You were right, ECM was okay.😊
Sounds crazy, but it cranks over easily now. Prior to this fix, the starter sounded weak, even with a fully charged battery.
Old 03-13-2015, 07:58 AM
Jimmy 68's Avatar
Originally Posted by car5car
16 hrs @ $85.00 US per hour labor= $1,360 plus 7% NJ sales tax $95, total $1,455
Old 03-17-2015, 01:33 PM
srdann's Avatar
Default Me Too
I am having the exact same problems with an '05 3.0 S type. Everyone says the stick is in Park but the trans is in Reverse. or thinks it is...Stick won't move-car won't start.
Oh, and it's 72 degrees and sunny
Old 03-17-2015, 02:06 PM
JagV8's Avatar
Received 4,559 Likes on 3,964 Posts
May be the 2 bolts on the trans side that hold the shifter cable are loose/missing.
Old 03-19-2015, 12:11 PM
srdann's Avatar
Jimmy, Wow my car also has a recent ding on the right front. Scraped from right front blinker to wheel well. Just a scrape. Do you think that could create the problem you had?
Old 03-19-2015, 12:13 PM
srdann's Avatar
Where are these bolts? under car or on shifter in car?
  #28
Old 03-19-2015, 12:14 PM
JagV8's Avatar
See: trans side
Old 03-19-2015, 06:41 PM
Jimmy 68's Avatar
No. My car ( long before I owned it), got hit in the front pretty bad, there is a slight ripple in the firewall, and the radiator support looks to be replaced as there are non factory spot welds.
With the above being said, I would not worry about it if your car only got hit as you described. My car was hit worse.
BrentGardner
28
04-26-2024 03:08 AM
fast40driver
04-19-2024 07:24 AM
Jaguila
09-05-2015 06:16 PM
1964Daimler
09-02-2015 11:41 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
Quick Reply: Car Will Not Start!
